datasavant
Apr 09, 2019Aspirant
rbr50 vpn
Trying to configure the router to use vnp, but ADVANCED>ADVANCED SETUP>VPN SERVICE says I am not connected to the network. Rather impossible since I just logged into the router as admin.
ekhalil
Apr 11, 2019Master
That's a bit wierd! I don't think that Orbi does a check for connectivity when opening the VPN Service setup page.
- Does the error message appear when opening the page or when trying to activate VPN Services?
- Do you have Orbi setup in Router or AP Mode? VPN Service works only when Orbi is in Router Mode.
- Do you have a DDNS configured under >> ADVANCED >> Advanced Setup >> Dynamic DNS? For VPN Service to work you have to have a DDNS configured
- datasavantApr 11, 2019Aspirant
Thanks for the input, but I am deciding to do something else as the ISP will not permit changes to their modem/router
- FURRYe38Apr 11, 2019Guru - Experienced User
Will they allow a DMZ setup in there modem? You might ask them this.
Good Luck.
