zahi_k
Aug 29, 2020Aspirant
RBR50 vs RBR50 v2
Hi, How do i know if my ORBI RBR50 is V2? I am currently on V2.1.4.16_1.1.31 and would like to upgrade to latest version. i don't want to break my router using a wrong version. Thanks,
Sep 08, 2020Guru - Experienced User
I would apply v212 then v2.5.1.16 to the RBR. You should be able to directy update to v16 on the RBS with out the v212. Update the RBS first.
zahi_k wrote:Hi,
Thanks,
- zahi_kSep 10, 2020Aspirant
I tried to load V 212 with no luck.
the RBR is saying the firmware file is incorrect.
