zahi_k
Aug 29, 2020Aspirant
RBR50 vs RBR50 v2
Hi, How do i know if my ORBI RBR50 is V2? I am currently on V2.1.4.16_1.1.31 and would like to upgrade to latest version. i don't want to break my router using a wrong version. Thanks,
Mstrbig
Sep 17, 2020Master
and none of these earlier ones work?
http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.5.1.8.zip
or even older:
http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.3.5.30.zip
Have you reached out to Netgear for locations of the firmware you may need?
Did you factory reset before attempting to try the different firmwares?
