zahi_k
Aug 29, 2020Aspirant
RBR50 vs RBR50 v2
Hi, How do i know if my ORBI RBR50 is V2? I am currently on V2.1.4.16_1.1.31 and would like to upgrade to latest version. i don't want to break my router using a wrong version. Thanks,
Sep 23, 2020Guru - Experienced User
Any progress on this?
zahi_k wrote:Hi,
Thanks,
- zahi_kSep 24, 2020Aspirant
Hi,
none of the TFTP solutions worked....
i followed every step.
when i reset the device, all manuals say i will end up with some flashing LED, that start with stable orange and ends with flashing red... for my case, whenever i remove the reset pin, it flash 3 times and then turn green...
BTW, i was following other threads... can i do anything over telnet? i have managed to go through the debug.htm page and enabled telnet....
- FURRYe38Sep 25, 2020Guru - Experienced User
Not to my knowledge...Shame the TFTP won't work. :smileyfrustrated:
