arunprasanth
Feb 13, 2021Tutor
RBR50 vs RBR50v2
I have an option to keep either RBR50 or RBR50v2. Assuming RBR50v2 is just revised model to keep manufactoring cost down with mem and port differences which one should I keep? Need help in deciding. ...
CrimpOn
Feb 13, 2021Guru - Experienced User
In practice, they are identical. You are correct that Netgear reduced the memory in the v2 model, most likely because they discovered it was not being used. The Orbi's will use the same amount of electricity, whether the power supply is rated at 2.5amp or 3.5amp.
Support for mounting a USB stick will never happen.
If I were in your position, I would keep the second one as a spare. (which, in fact, I did by purchasing one on eBay.)
arunprasanth
Feb 13, 2021Tutor
Thanks for clarifying on the power consumption part. Regarding the spare, do you think RBK50's is prone to failure in the long run? For my 2000sqft, two level home, I finally settled with mesh solution thinking this will solve all problems, after trying several medium powered single routers (archer C4000, RAX45, AX21 routers). All of those single router solution caused high packet loss and/or ping latency with my xbox in living room. I cant centrally locate the router due to cabling from ISP to one side of the house. Before going up to powerful gaming routers, I thought I ll try a mesh. So far I havent seen packet loss at least once in the xbox native network tests. Wired backhaul is not gonna happen for me. Sorry for going detailed on my story while the topic is for something simple.
