arunprasanth
Feb 13, 2021Tutor
RBR50 vs RBR50v2
I have an option to keep either RBR50 or RBR50v2. Assuming RBR50v2 is just revised model to keep manufactoring cost down with mem and port differences which one should I keep? Need help in deciding. ...
arunprasanth
Feb 13, 2021Tutor
Thanks for clarifying on the power consumption part. Regarding the spare, do you think RBK50's is prone to failure in the long run? For my 2000sqft, two level home, I finally settled with mesh solution thinking this will solve all problems, after trying several medium powered single routers (archer C4000, RAX45, AX21 routers). All of those single router solution caused high packet loss and/or ping latency with my xbox in living room. I cant centrally locate the router due to cabling from ISP to one side of the house. Before going up to powerful gaming routers, I thought I ll try a mesh. So far I havent seen packet loss at least once in the xbox native network tests. Wired backhaul is not gonna happen for me. Sorry for going detailed on my story while the topic is for something simple.
CrimpOn
Feb 13, 2021Guru - Experienced User
My Orbi is going strong after four years. My mantra, however, is everything can fail. Cars fail. refrigerators fail. Airplanes fall out of the sky.
Is the Orbi "prone to failure"? I think not. But, what happens if one day it does fail? You will have zero internet until Amazon delivers some new product for you to install. Or, you can plug in that spare Orbi, upload the saved configuration, and be back in business in 30 minutes.
I could see a decision not to spend more money to purchase a spare, but if it's already here?
