Embuff's avatar
Embuff
Initiate
Sep 04, 2021
RBR50 w/ RBS50 satellites showing up numerous times
I have 1 RBR50 with 2 RBS50 satellites. For some reason, one of them shows up dozens of times with an older firmware version (it goes on a lot longer than the image.) Not sure if related, but my internet connection seems less reliable since this started. Any suggestions on how to fix it?
1 Reply
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update using a wired PC and web broswer?
