danfCO
Mar 16, 2020Follower
RBR50 w2 satellites dropping wifi every night
I have one RBR50 and two RBS50 satellites all running V2.5.1.8. Internet has been very stable. Each night over the last 5 nights, My devices are not able to reach the internet. When I log into my orbi system, it says the internet connection is good. I can't seem it isolate the issue. I reboot the system in the morning and it then works fine for the day unitl I wake up and find the same issue.
Sort By
- Retired_Member
danfCO wrote:I have one RBR50 and two RBS50 satellites all running V2.5.1.8. Internet has been very stable. Each night over the last 5 nights, My devices are not able to reach the internet. When I log into my orbi system, it says the internet connection is good. I can't seem it isolate the issue. I reboot the system in the morning and it then works fine for the day unitl I wake up and find the same issue.
Get rid of V2.5.1.8.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925Has a factory reset and setup from scratch been performed since last FW update?
- Retired_Member
:smileysad:
no copy paste will fix bad FW
