stickx911
Apr 28, 2020Aspirant
RBR50 WAN stuck at 100mbps
My rbr50 Wan port will not see anything higher than 100mbps. After trying every cat6 cable in the house, I tested AP mode and borrowing another moder/router and plugging into any other lan port, I ge...
stickx911
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN 100M/Full 195413 226245 0 35082 88878 00:44:38 LAN 1 1000M/Full 233557 191774 0 28887 22924 00:44:30 LAN 2 1000M/Full 00:44:30 LAN 3 100M/Full 00:44:30 WLAN b/g/n 400M 32934 1733 0 240 65 00:43:58 WLAN a/n/ac 866M 340062 363229 0 27888 12565 00:43:53 WLAN Backhaul
tomschmidt
Apr 28, 2020Virtuoso
Since you tested your cable and modem and verified they are working at gigabit speed with another modem, then your RBR50 may be defective. If it is still under warranty, then contact Netgear support for an RMA.
You might also try a factory reset to see if that corrects the issue. Save your configuration first so that you can restore it if needed, or at least take screenshots of each configuration screen that you customized settings on. NG support may also request you to factory reset it as part of their troubleshooting process before issuing you an RMA.
FYI, I subsribe to 100Mb/s speed from my ISP, but my WAN connection to my modem is 1000M/Full.
