Blaise123
Apr 07, 2020Follower
RBR50. Wi-Fi signal dropping
My Wi-Fi signal has been dropping a few times a day for a few minutes . We have been using it much more heavily the last 2 weeks . It usually self heals in a few minutes . Occasionally it does not c...
Apr 07, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Has a factory reset and setup from scratch been performed since last FW update? If not, try this...
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
- Retired_MemberApr 07, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update? If not, try this...
https://www.youtube.com/watch?v=ePZSc7vnRlQYou could simplify this by only asking What Firmware version is currently loaded?
