57mchan
Aug 10, 2018Tutor
RBR50 WiFi Calling Quit Working
Our WiFi Calling capabilities stopped working yesterday on both mine and my wife’s iPhone 6s cell phones that are running current iOS version 11.4.1. WiFi Calling had been working quite well since pu...
57mchan
Aug 11, 2018Tutor
I don’t recall when the firmware was updated, so I know WiFi Calling has worked since the last update to v.14.
My ISP setup is kind of unique. I live out in the country and have a wireless broadband service provider. And this ISP leases space on my tower. So, as part of the lease, I have a cat 5e cable running from my Orbi router out to the tower and into an ISP owned switch. It is small cheap Dynex DX-GB8PRT and has several items connected, service to me being just one of the items. That switch gets its input from something installed up the tower.
I have set the SIP back to default of being on after my test.
Thanks,
Doug
Aug 11, 2018Guru - Experienced User
You might power OFF the ORbi and satellites for 1 minute or two, then power them back on and test.
I can't find much info on this switch:
https://www.dynexproducts.com/pdp/DX-GB8PRT/1570067
https://www.amazon.com/GIGABIT-ETHERNET-SWITCH-DX-GB8PRT-PACKAGING/dp/B004MF1BZW
Not sure if it's managed or non managed. There as been users reporting issues with Orbi systems and managed switches. I don't think this one is managed.
You might power OFF the switch for 1 or two minuts as well if you have access to the switch while you do the same with the orbi. Then last power ON the Orbi system and test.
