kalfaz
Jan 02, 2024Aspirant
RBR50 wifi clients connected without internet - intermittent but frequent enough to cause concern
RBR50 with one RBS50 (wireless backhaul) V2.7.4.24 Environment is 1800 sq ft residential 70s construction pine studs and drywall. ISP is ATT Fiber and RBR is Cat 6 connected to ATT Pace 5268ac. ...
CrimpOn
Jan 02, 2024Guru - Experienced User
The DHCP lease time for user devices remains 86,400 seconds (one day). Netgear removed the telnet option, possibly because of customers harping about how "insecure" telnet it. Or, because telnet was never available in the AX product line and someone decided to make them consistent. Without telnet, the way to determine the lease time is to capture the DHCO lease offer packet with a packet sniffer and find the value inside the packet. I use Wireshark (free for Windows, Linux, Mac)
My Android Orbi app has a disappointing pattern of connecting by default with Anywhere Access and then, almost as an accident, mentioning that "local connection is available". My guess is that what is happening is the app attempts to use Anywhere Access, cannot make a connection to the Netgear 'cloud', and gives up before it would have attempted to find a local connection. This behavior annoys me a lot.
A magenta ring indicates the router cannot connect to the internet. See page 9 in the user manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- kalfazJan 02, 2024Aspirant
Good idea - I'll look for Access Anywhere, in the mean time I turned off daisy chain as I only have one satellite.
When it appears, the purple ring is only on the satellite.
