kalfaz
Jan 02, 2024Aspirant
RBR50 wifi clients connected without internet - intermittent but frequent enough to cause concern
RBR50 with one RBS50 (wireless backhaul) V2.7.4.24 Environment is 1800 sq ft residential 70s construction pine studs and drywall. ISP is ATT Fiber and RBR is Cat 6 connected to ATT Pace 5268ac. ...
kalfaz
Jan 03, 2024Aspirant
Great points FURRYe38 ,
I should have mentioned the Pace 5268 is already set just as you described in Option 2: IP Passthrough with DMZ+ for years now and that setup has worked well for the Nighthawk I had before I switched to Orbi and this Orbi itself has ran for at least 5 months without giving the connected without internet error to the wifi clients.
I just moved the satellite a few more feet away and it is now about 40 feet away, the article you linked doesn't really specify anything about distance so I'm hoping 40 is the sweet spot. If 25ft is too close how far is too far?
Our house looks a lot like the first pic labelled Midsize single-story home
V2.7.4.24 is most current firmware
I was considering downgrading to try the telnet option to reduce that lease timer but would that really cause an issue that only affects wifi clients, there are 3 computers on wired interfaces that never have a problem it is isolated to the wifi clients.
Jan 03, 2024Guru - Experienced User
Thank you for confirming the mode.
Too far is maybe when the status reports POOR on the RBRs web page for the RBS or a top ring LED turns on PINK. Means signal is not good. OFF means a GOOD signal with the RBS and RBR.
There a size in Sq Feet of this home?
There is more current FW available, Check here in the forum for information regarding newer FW at the top.
- kalfazJan 04, 2024Aspirant
1800 sqft
regarding color of ring I'm nearly certain that I've had the "connected without internet: on the android client and the ring was not glowing.
- FURRYe38Jan 04, 2024Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
