tupac21354
Dec 20, 2019Aspirant
RBR50 WiFi Drops
I have the Orbi RBR50 and having issues with wifi dropping at night sporatically. All of my hard wired connected devices remain connected to the internet and working fine but the wifi doesn't work. I...
Dec 20, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Been running v2.5.1.8. Doing good thus far:
https://community.netgear.com/t5/Orbi/Firmware-v2-5-1/td-p/1836035
tupac21354 wrote:I have the Orbi RBR50 and having issues with wifi dropping at night sporatically. All of my hard wired connected devices remain connected to the internet and working fine but the wifi doesn't work. I've reviewed the orbi logs and the only log entry that shows a possible issue would be an entry with this tag: [Internet connected]. My theory is that if there is any type of modem reset from my ISP that orbi can't handle this reconnection for wifi but it works fine for their hard wired ports. I'm not sure how else to troubleshoot this issue so asking for any help the community can offer up. It's getting pretty annoying having to reset my orbi so frequently to get wifi to work again. My device firmware is update to date (V2.5.0.38).
Thanks!
- tupac21354Dec 21, 2019Aspirant
Thanks for the suggestions. Here are more details around how things are configured now and my one remaining issue.
- ISP modem -> xfinity xFi Gateway (TG3482G)
- house -> 2500 sq. ft.
- orbi devices about 20'-30' apart (satellites on floors 1 and 3 while main orbi router is on floor 2)
- 2.4 was set to 'auto' but updated to be on channel 6 (used wifi inspector: https://www.cambiumnetworks.com/products/software/free-tools/)
- enabled beamforming
- updated firmware to 2.5.1.8 (took the risk...)
I have one problem after this upgrade though since all my devices no longer show up in the attached devices list anymore through the admin web portal and also through the latest ios app. I didn't perform a factor reset after the firmware upgrade though since I wasn't sure what exactly i would have to reconfigure as a result of this.
Thanks!
