cheadrick
Dec 17, 2021Initiate
RBR50 WiFi iPhone Privacy Warning
iPhone 8 iOS 15.1 iPhone 12 iOS 15.1 Orbi RBR50 router firmware V2.7.3.22 No new firmware available Orbi RBS50 Satellite firmware V2.7.3.22 No new firmware availab...
Chickenlips
Jan 25, 2022Aspirant
Has there been any response from Orbi about this? Is it something that can be addressed?
Jan 25, 2022Guru - Experienced User
This is mostly a Apple issue. Since Apple implemented this Wifi Privacy Address feature, this seems to be the main cause of it.
It's recommended, if your not travelling afar from home, disable this feature on your Apple devices as the random chaning of the devices MAC addresss really isn't needed while your at home or local work environment. IF you are travelling, then of course, have this feature enabled.
https://www.iphonetricks.org/how-to-fix-wifi-privacy-warning-on-iphone/
Something that Apple should be asked about since this is there feature they came up with.
