Omair
Dec 17, 2022Aspirant
RBR50 Wifi Keeps Dropping
My RBR50 has been stable for the past 2 years. 2 months back it started acting up. I have updated the firmware. LAN connectivity is stable and I am able to access orbi login. RBR50 lights are stable. ...
Omair
Dec 18, 2022Aspirant
Anyone?
KevinLiT
Dec 20, 2022NETGEAR Moderator
Hello Omair,
Welcome to the NETGEAR Community!
I understand that you are having issues with your internet connection with RBR50. I noticed that you are not getting any connection between your RBR50 and your ISP. This can occur if your ethernet cable is damaged. Please replace the ethernet cable leading from your RBR50 WAN port to your ISP router.
Best,
Kevin
Community Team
