IslandStylin
May 18, 2024Aspirant
RBR50 Wifi Mesh Internet is Painfully Slow
Aloha Everyone, 1x Spectrum Modem (model E31U2V1) 1x RBR50 Router (Firmware: V2.7.4.24) 3x RBS50 Sattelite (Firmware: V2.7.4.24) Home Square Footage: Roughly 5000SqFt I am pulling my ha...
May 18, 2024Guru - Experienced User
What device are you testing with?
The 2.4ghz isn't going to get faster speeds than roughly that 100mbps (or even lower) but the 5ghz should.
How are you testing speeds? What app? What device? How far from router? or satellite?
Have you tried the scorched earth policy and tried a factory reset?
- IslandStylinMay 18, 2024Aspirant
Thanks for pointing out that question.
I am using a macbook pro, iphone 12 min and a late imac 2015 model.
I have been using: google speed test, spectrum speed test, ookla speed test and ookla speed test app on iphone along with spectrum/google speed test on chrome browser.
I have done a factory reset at this point. I feel as though it has not improved.
- plemansMay 18, 2024Guru - Experienced User
How old is the orbi?
did it ever hit faster wireless speeds?
What link speed are you showing when you test the speeds?
Any windows/android devices to try testing?
The orbi is old. At least 6-7 years at this point.
I recall hitting faster speeds before. I also hit normal fast speeds when directly connected to a satellite or router.
Right now I just tested a ThinkPad using Internet Explorer and received 123 down and 22 up and one minute later re-tested and its at 40 down and 22up.
Seems that the download speed is hindered greatly, which is odd.
