ballscommaD
Sep 19, 2022Aspirant
RBR50 wifi not working on random devices while others are fine?
I have Verizon Fios running straight to an Orbi RBR50 with two satellites. All of a sudden I have TV's not getting internet even though signal is extremely strong, SSID is showing on the screen, and ...
CrimpOn
Sep 19, 2022Guru - Experienced User
ballscommaD wrote:
All of a sudden I have TV's not getting internet even though signal is extremely strong, SSID is showing on the screen, and a TV in the other room is working perfectly.
This TV worked until recently?
The SSID is "showing on the screen", and after entering the correct password the TV shows as "connected".
Does the Orbi show this TV as connected?
Can you describe the wording of the error message?
