ballscommaD
Sep 19, 2022Aspirant
RBR50 wifi not working on random devices while others are fine?
I have Verizon Fios running straight to an Orbi RBR50 with two satellites. All of a sudden I have TV's not getting internet even though signal is extremely strong, SSID is showing on the screen, and ...
Sep 19, 2022Guru - Experienced User
What fios box is it connected to?
Reason i ask is they tend to be modem/router combo devices and it causes a double nat if not setup properly.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
KevinLiT
Sep 20, 2022NETGEAR Moderator
Hello ballscommaD,
Welcome to the NETGEAR Community!
Which firmware is currently loaded in your RBR50?
Best,
Kevin
Community Team
