bhireg0
Aug 14, 2023Follower
RBR50 WiFI router kicked the bucket this morning and won't connect again
My RBR50 router was working fine until my connection just dropped this morning. I checked the back of the router and I saw that the power light was flashing red with a white ring at the top. I search...
michaelkenward
Aug 15, 2023Guru - Experienced User
bhireg0 wrote:
My RBR50 router was working fine until my connection just dropped this morning. I checked the back of the router and I saw that the power light was flashing red with a white ring at the top. I searched it up and it said that it was a corrupted firmware.
Sadly, that sounds very much like you are into TFTP territory, where wild animals roam.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
