DCP4971
Apr 01, 2022Luminary
RBR50 wifi speed slowdown
Hi all, Bit of a puzzler for me, so thought I'd ask the hive mind.. RBR50 with 2 RBS50s, running FW 2.7.3.22 connected to cable modem, running 1.1gb connection from ISP. I'm getting regul...
DCP4971
Thanks for the reply:
- Think it's an Arris something or other, it's not clear as it's branded as the ISP.
What is the distance between the router and ? satellite(s)? 30 feet or more is recommended in between RBR and RBS? to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ?
- They are probably about 20ft from the RBR and on different floors, we have some very thick walls that caused me to place them closer to get the best performance and range. Especially covering out into the garden and into the loft where we have a room and with just one RBS the coverage was poor.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Using Ch 48 and Ch 13 as others have local wifi on them from neighbouring properties
- c10 other wifi signals picked up. All on different channels to those I am using
Is Armor, Circle or Traffic Meter enabled?
- SPC is enabled, no Armour or TM
Apr 01, 2022Guru - Experienced User
- Think it's an Arris something or other, it's not clear as it's branded as the ISP. <There a sticker that may have a model#? Just checking to see if this modem has a router and wifi built in or not.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- SPC is enabled, no Armour or TM <Possible SPC could be slowing things down. A factory reset maybe needed and setup from scratch and don't enable SPC to see if this changes anything.
- DCP4971Apr 01, 2022Luminary
Thanks again.
- It an Arris TG3492LG-VMB does have wifi built in, but it is off.
- I'll have a crack at that
- Had a horrid feeling you were going to suggest a FR đ€Ł - will keep this in reserve. Have had issues with SPC slowing down specific traffic (Playstation network traffic defo looks throttled to me, but everything else seems fine)
What's most odd with all this is that it was an issue that went away for a decent amount of time and is now back, despite nothing obvious changing. Hey-ho, will start with the power output and see how things go from there.
Cheers
- FURRYe38Apr 01, 2022Guru - Experienced User
DCP4971 wrote:
Thanks again.
- It an Arris TG3492LG-VMB does have wifi built in, but it is off. <Even tough the wifi is off, this modem has a built in router and its enabled. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- c10 other wifi signals picked up. All on different channels to those I am using
Cheers
