mdragon24
Mar 02, 2024Aspirant
RBR50 wifi speeds slow despite 1Gb fiber plan from Frontier
Hi Everyone, I have a RBR50v2 which was previously hooked up to a Spectrum modem w/ a 400mb down 20 up plan. No issues for years. I recently switched the modem to a frontier modem for a 1GB fiber pla...
- Mar 04, 2024
I called Netgear support and they had me change my channels off auto to some other channels as well as set my DNS settings off auto and to Googles DNS settings (8.8.8.8 and 8.8.4.4). This pretty much solved the issue! Getting around 520 download and ~400 upload. I'd say that's pretty good and likely the most i'll get.
CrimpOn
Mar 02, 2024Guru - Experienced User
This indeed is not what one would expect. People often have unrealistic expectations about performance over WiFi connections. (Try internet searches for "WiFi speed to expect", etc.)
However, in this case, something does appear to be "not right". My RBR50 delivers 360Mbps from a Spectrum cable connection, which is actually more than they guarantee. But, that is certainly more than 100Mbps. And, the same speed is reported by
- The router Speed Test
- A computer hard wired to the router
- Various devices connected over WiFi (laptop, tablet, smartphone)
What sort of devices are reporting this puny speed?
How are they connected to WiFi?
- Directly to the router or to a satellite?
- At 5G or 2.4G?
mdragon24
Mar 03, 2024Aspirant
- Iphone 14 pro
- Macbook M2 pro
Are just two examples of over 15 devices in the home that are all reporting slower than normal speeds. They're connected directly through the 2.4/5ghz wifi network through a home of around 1300 sq ft. There is one RBR50 router and 2 satellites. I even tested turning off the satellites and connecting devices to wifi directly to the router. But same issue, roughly 100mbps down and 200mbps upload.
What do you think could be happening here?
Thanks!
- mdragon24Mar 04, 2024Aspirant
- FURRYe38Mar 04, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
