mdragon24
Mar 02, 2024Aspirant
RBR50 wifi speeds slow despite 1Gb fiber plan from Frontier
Hi Everyone, I have a RBR50v2 which was previously hooked up to a Spectrum modem w/ a 400mb down 20 up plan. No issues for years. I recently switched the modem to a frontier modem for a 1GB fiber pla...
- Mar 04, 2024
I called Netgear support and they had me change my channels off auto to some other channels as well as set my DNS settings off auto and to Googles DNS settings (8.8.8.8 and 8.8.4.4). This pretty much solved the issue! Getting around 520 download and ~400 upload. I'd say that's pretty good and likely the most i'll get.
mdragon24
Mar 03, 2024Aspirant
- Iphone 14 pro
- Macbook M2 pro
Are just two examples of over 15 devices in the home that are all reporting slower than normal speeds. They're connected directly through the 2.4/5ghz wifi network through a home of around 1300 sq ft. There is one RBR50 router and 2 satellites. I even tested turning off the satellites and connecting devices to wifi directly to the router. But same issue, roughly 100mbps down and 200mbps upload.
What do you think could be happening here?
Thanks!
mdragon24
Mar 04, 2024Aspirant
- FURRYe38Mar 04, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
