mmcdds's avatar
mmcdds
Follower
Feb 20, 2021
RBR50 wired connections no longer work, wireless connections work fine
My home network was working fine until we didn't have power with the winter weather in Texas the past several days.  After power returned, my network would not recognize any of the ethernet connected devices.  I have an Obi RBR50 (firmware 2.7.2.104) router with 2 satellites.  All of the wireless devices seem to function normally.  I have Xfinity internet connected to a Netgear CM700 cable modem, which i don't believe has any function as a router.
CM700<---->Orbi RBR50<---->Synology NAS, classic MacPro, Drobo 5N + other wired devices through Netgear switches.
The classic MacPro and my Macbook Pro will both connect to the internet wirelessly.  When connected directly to the RBR50, through ethernet, both computers give me a "self assigned IP address" message.  I have changed the ethernet cable 2x between the CM700 and the RBR50 and did not seem to help.  Last night, I factory reset the RBR50 which seemed to make no difference to the wired connections.  The wireless connections work fine.
Not sure where to go from here or if I am approaching this problem correctly.  Any help would be appreciated.
  • There are several reports of problems with (firmware 2.7.2.104)
    you may want to roll yours back.
  • FURRYe38's avatar
    • vajim's avatar
      vajim
      Master
  • In the router menu: Advanced, Router/AP mode does it say it's in Router mode?  Sounds like the DHCP server isn't issuing IPs to the wired devices.  Do all of your wired devices go through your switch or have you bypassed the switch and tried directly to a computer?
