Collin88
Sep 01, 2018Aspirant
RBR50 wired speeds cut in half
Hi guys,
I've been having problems with my ORBI RBR50 and sattlelite lately. I'm not very tech savy when it comes to networking so maybe I'm missing something here.
I have 1GBS internet b...
Collin88
Sep 02, 2018Aspirant
FW: V2.1.4.16
Modem is called ZHONE
Model # is: ZNID-GPON-242A-NA
Nothing has been enabled since factory reset no settings changed. Connected through PPOE.
Sep 02, 2018Guru - Experienced User
Does the ONT have a built in route by chance? You might try enabling the router on the ONT then connect the Orbi in router mode and input it's IP address into the ONTs DMZ. Or try the Orbi in AP mode...
