mkprasanna's avatar
mkprasanna
Follower
Dec 10, 2021
RBR50 wireless mesh router issue with airplay
Hello,
I have observed that when my Apple Home pod speaker is connected to one of the Orbi rbr50
satellite then airplaying music from my iphone to that homepod does not work.
Does any one know of a fix for this.
Thanks
Prasanna
1 Reply
  • FURRYe38's avatar
    Does the airplay work if both are connected to the RBR or RBS?
    Is Armor, Fast Roaming or Smart Parental controls enabled on the RBR?
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
