hartcb
Dec 28, 2020Tutor
RBR50 with 1 RBS50s - Wifi Calling Drops Constantly - on latest firmware V2.7.2.102
Hi All, I've been working on this issue for 2+ months and have made all the rounds - to Apple, to Verizon, and read through all the forums here for similar issues. It seems no matter what I try,...
- Dec 31, 2020
UPDATE - xfinity modem replaced, connectors on my line snipped and reconnected, and wifi calling seems to be working. 20 minute call is just completed and still running. I believe that was ultimately the issue.
So, after investigating with Netgear equipment, Apple phones, my network, various settings, etc... it came down to the cable / internet provider. I don't know that I'll ever know what caused it, but happy it appears to be fixed! Hopefully, this helps someone else.
Dec 28, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
hartcb
Dec 28, 2020Tutor
Thanks for the response - please see below:
- The ISP Modem is a xfinity XB6-A
- Home size is 2,000 square ft. plus or minus (with 1 router and 2 satellites I have very strong signal throughout the house)
- Distance router to satellite is 15 ft. (but going through a couple of walls) on one and 25 ft. (going through a door) for the other. This has been the configuration for 2 years or so with no issues until the last 2.5 months.
- 2.4Ghz was Auto, changed setting to manual channel 1
- Wifi Neighbors - just one shows up and only 2 bars (ATT)
- Beamforming and MIMO were already enabled from prior post suggestions - left those on
- Factory reset and setup - done just before I updated to the latest firmware today.
- Per the other post you included a link to I have now given both satellites static IP addresses as well.
- All other configurations are as you suggested.
RESULT: wifi calling is still dropping after 2-3 minutes on average, this continues to happen if I am on wifi only (airplane mode with VZW Wi-Fi on the iPhone), or have the cellular on (my at home cell service is terrible, hence the need for wifi calling - definitely is harming my work at this point...)
- FURRYe38Dec 28, 2020Guru - Experienced User
What mode is your modem working in? Router or modem only. Thats a modem with built in wifi and router I believe. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopThe 1 RBS thats 15 feet from the RBR is too close. 30 feet is needed. 2000sq ft maybe too small an area for two RBS. Try turning OFF 1 of the RBS.
- hartcbDec 28, 2020Tutor
Thanks again, please see below:
- Xfinity XB6 was already set to bridge mode - just confirmed that
- Wi-Fi disabled on Xfinity XB6
- Orbi is in router mode
- That's interesting, I didn't realize too close was an issue. What would be strange is that it worked like this for a couple of years with nothing changing and then stopped, but stranger things have happened. I moved both satellites farther away from the router - now one is about 35 feet and the other is about 30 (we have the space). The irony would be that I thought I should be moving closer if anything!
RESULT: Just hit 10 minutes on a wifi only test call for the first time in a long time. I'm hopeful that this could be the fix I have been looking for! I'll update here after running some additional tests over the next day or so. If this is the fix, it would be helpful for others pulling their hair out to know that this particular sub-optimal physical configuration of less than 30 feet causes this specific wifi-calling drop issue (maybe these keywords help) - would have saved me about 12 hours of my life :)
Ok, Hopefully this is all thats needed.
So Beamforming, MIMO and WMM is enabled?
Daisy Chain disabled?
I'm using manual channel 11 and 48...
You can try setting CTS to 2307 Under Advanced Tab/Advanced Settings/Wireless Settings.
So if you turn OFF the RBR and re-enabled the wifi radios on the modem, wifi calling works?
- vajimDec 29, 2020Master
:smileysad:
- hartcbDec 29, 2020Tutor
So, continued testing and I think I've narrowed it down to an Comcast Xfinity issue: https://forums.xfinity.com/t5/Your-Home-Network/WiFi-calling-drops-repeatedly/m-p/3398290/highlight/false#M340231
I did connect directly to the Xfinity modem with wifi on, turned all Netgear Orbi devices off and still had the same dropping issue. So, it can't be the Orbi network, it can't be the iPhone since that worked in airplane mode on a different wifi network (Starbucks), so by default it must be Xfinity.
I also have a ticket with Apple engineering and they advised to test with "cellular data" turned off to see if that did anything - nope.
Opening a ticket with comcast, but not too optimistic given other people's experiences in the above thread. Thanks much FURRYe38 for all the advice and troubleshooting. That definitely helped me narrow down to the likely suspect.
- FURRYe38Dec 29, 2020Guru - Experienced User
Great to hear. Ya I have put my RBK50 online in router mode today. I haven't had a chance to test wifi calling yet.
Sounds like you are now going the right direction. Hopefully your ISP can get this fixed.
