Schmitty1226's avatar
Jun 26, 2021
RBR50 with 1 satellite
So I live in a split foyer house. It's about 1400sqft. The router is in the master bedroom which is on the far end of the house. The satellite is in the basement on the other end of the steps. I tried...
  • FURRYe38's avatar
    A wired connection between the RBR and xbox would be best.
    Good Luck.
