Schmitty1226
Jun 26, 2021Tutor
RBR50 with 1 satellite
So I live in a split foyer house. It's about 1400sqft. The router is in the master bedroom which is on the far end of the house. The satellite is in the basement on the other end of the steps. I tried...
- Jul 02, 2021
A wired connection between the RBR and xbox would be best.
Good Luck.
Schmitty1226
Jun 30, 2021Tutor
Firmware is V 2.7.2.104
Don't have a modem. It's satellite internet.
About 1400sqft is my split foyer home.
The satellite is about 40-50ft away and on a different level. I'm very confused now because I moved my satellite and am getting better signal but my xbox which is wired into the satellite is getting WAY worse. I'm getting 31mbps on my phones wifi and only 23.51mbps on my wired Xbox.
Jun 30, 2021Guru - Experienced User
You might move the RBS a bit slower to the RBR maybe.
