Schmitty1226
Jun 26, 2021Tutor
RBR50 with 1 satellite
So I live in a split foyer house. It's about 1400sqft. The router is in the master bedroom which is on the far end of the house. The satellite is in the basement on the other end of the steps. I tried...
- Jul 02, 2021
A wired connection between the RBR and xbox would be best.
Good Luck.
Schmitty1226
Jul 01, 2021Tutor
It wasn't any better. I moved my xbox back to where it was and I'll just keep it there. Thanks again for all the help
Jul 02, 2021Guru - Experienced User
Good Luck.
