Batdoc31
Apr 02, 2019Aspirant
RBR50 with 2 Hardwire RBS50 and switch Problem
All,
About to give up despite the large investment Ivemade in Orbi. Originally I had 1 RBR50 and 2 hardwired RBS50 and then 2 RBW20 plugin satellites for a large home. Ive replaced every bit o...
Apr 02, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
