Batdoc31
Apr 02, 2019Aspirant
RBR50 with 2 Hardwire RBS50 and switch Problem
All,
About to give up despite the large investment Ivemade in Orbi. Originally I had 1 RBR50 and 2 hardwired RBS50 and then 2 RBW20 plugin satellites for a large home. Ive replaced every bit o...
ekhalil
Apr 02, 2019Master
I didn’t get with which configiration you see the reduced speed issue.
You said that you get same results with wired and wireless Satellites. With which configuration do you get the full 350 Mbps speed?
- Batdoc31Apr 02, 2019Aspirant
LATEST Firmware is the most up to date for RBR50 and satellites. Whether hard connected (Ethernet backhaul) or wirelessly connected I get the fast speeds. In either scenario everything starts to fail as soon as I connect the switch reducing my speeds to 5-10Mbps
- ekhalilApr 02, 2019Master
Batdoc31 wrote:
........ everything starts to fail as soon as I connect the switch reducing my speeds to 5-10Mbps
- What switch do you use?
- Do you connect it to the Router or Satellite?
- What other wired devices do you have attached to Orbi nodes?
Ive tried multiple switches both new and same problem. Interestingly enough I have a switch connected to one of the satellites and I have no problems its only the switch connected directly to the Orbi router that causes this.
I have some home audio equipment connected to the main switch in an electronics closet as well as home automation and a verizon network extender.
