Batdoc31
Apr 02, 2019Aspirant
RBR50 with 2 Hardwire RBS50 and switch Problem
All,
About to give up despite the large investment Ivemade in Orbi. Originally I had 1 RBR50 and 2 hardwired RBS50 and then 2 RBW20 plugin satellites for a large home. Ive replaced every bit o...
Batdoc31
LATEST Firmware is the most up to date for RBR50 and satellites. Whether hard connected (Ethernet backhaul) or wirelessly connected I get the fast speeds. In either scenario everything starts to fail as soon as I connect the switch reducing my speeds to 5-10Mbps
ekhalil
Apr 02, 2019Master
Batdoc31 wrote:
........ everything starts to fail as soon as I connect the switch reducing my speeds to 5-10Mbps
- What switch do you use?
- Do you connect it to the Router or Satellite?
- What other wired devices do you have attached to Orbi nodes?
- Batdoc31Apr 02, 2019Aspirant
Ive tried multiple switches both new and same problem. Interestingly enough I have a switch connected to one of the satellites and I have no problems its only the switch connected directly to the Orbi router that causes this.
I have some home audio equipment connected to the main switch in an electronics closet as well as home automation and a verizon network extender.
- FURRYe38Apr 02, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch?
I tried 2 different Netgear GS316 (16 port gigabit) switch thinking maybe the switch went bad and even tried a TPlink smart switch. All recreate the same issue!
- ekhalilApr 02, 2019MasterYou mentioned audio equipment connected to the switch. Any mesh speakers (e.g. SONOS)?
- Batdoc31Apr 02, 2019AspirantNope. Just Russound equipment and an nvr and some home automatiom
