AkoreJepade
Sep 22, 2020Tutor
RBR50 with 3 sats
Router RBR50 in main office front left corner of the house, have a RBS50 in the kitchen, sort of central in the house. Have a RBS50Y in the detached garage which in front of the house and closest to ...
- Sep 24, 2020
Even if you power OFF this one RBS for 30 seconds then back ON? It should connect to the nearest RBS, not the RBR. You might try rebooting the RBR while leaving the RBS on to see if they connect in daisy chain.
Mstrbig
Sep 22, 2020Master
AkoreJepade wrote:Router RBR50 in main office front left corner of the house, have a RBS50 in the kitchen, sort of central in the house. Have a RBS50Y in the detached garage which in front of the house and closest to the RBR50 main router, and last a RBS50Y at the back of the house outside. For some reason the back RBS50Y is connecting to the garage RBS50Y which is the fatherest device and as such is showing "Poor" under Backhaul Status. How to I get it to connect to the kitchen unit which is the closest to it?
If on, turn Daisy Chaining off and see if it fixes it.
AkoreJepade
Sep 23, 2020Tutor
Daisy chain is already off so I will try steps above and see if it will connect to the kitchen sat. Thanks for the replies!
- FURRYe38Sep 23, 2020Guru - Experienced User
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
AkoreJepade wrote:Daisy chain is already off so I will try steps above and see if it will connect to the kitchen sat. Thanks for the replies!
- AkoreJepadeSep 23, 2020Tutor
Down here in Colombia the construction is very hard on WiFi due to it all being cement, adobes, cement block and rebar reinforced concrete due to earthquakes. 30 feet here like 15 feet in a normal house. :smileyvery-happy:
Thats true so ya, closer the better in that case.
