DM2020
Mar 28, 2020Aspirant
RBR50 with 5 Satellites WIFI Speed Slow
Hi All, I have an ORBI RBR50 with 5 satellites. Version 2.4.23.1 I have Frontier Fiber 500gb/500gb. My wifi speeds have been atrocious. 3-5mb download, 8 mb upload. I am not super tech savvy. Are ther...
DM2020
Apr 17, 2020Aspirant
So sorry for the delay. I directly hooked up to the router and got speeds of 3.35mb/6.3mb. Then, I hooked up directly to the modem and I got speeds of 156mb/151mb.
So the problem is in the router. Any ideas on how to fix this?
Retired_Member
Apr 17, 2020
DM2020 wrote:So sorry for the delay. I directly hooked up to the router and got speeds of 3.35mb/6.3mb. Then, I hooked up directly to the modem and I got speeds of 156mb/151mb.
what kind of modem do you have?
you do know that the Orbi requires some sort of modem...???
- DM2020Apr 17, 2020Aspirant
The modem is Frontier Arris nvg468mq.
- Retired_MemberApr 17, 2020
DM2020 wrote:The modem is Frontier Arris nvg468mq.
that may be one that has a router built in......it can work with the Orbi as long as one is configured as a AP.
otherwise your life will be better off if you get a regular straight up modem (no built router)...IF FIOS will allow it.....
