DM2020
Mar 28, 2020Aspirant
RBR50 with 5 Satellites WIFI Speed Slow
Hi All, I have an ORBI RBR50 with 5 satellites. Version 2.4.23.1 I have Frontier Fiber 500gb/500gb. My wifi speeds have been atrocious. 3-5mb download, 8 mb upload. I am not super tech savvy. Are ther...
Mar 28, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
DM2020 wrote:
Hi All, I have an ORBI RBR50 with 5 satellites. Version 2.4.23.1 I have Frontier Fiber 500gb/500gb. My wifi speeds have been atrocious. 3-5mb download, 8 mb upload. I am not super tech savvy. Are there any thoughts as to why it is this bad? Thanks in advance.
DM2020
Apr 17, 2020Aspirant
So the modem is Frontier. The Netgear router is the RBR 50 with 5 satellites. The home size is 5700 sqft. The modem is a arris nvg468mq by Frontier. My Orbi is in AP (access point) mode.
Direct connect to modem: 151/156mb.
Direct connect to router: 3/6mb.
There is an issue in the router. I don't know much about settings but I do see the 2.4ghz set to auto and the 5ghz set to 48.
I also highlighted and copied this:
| Region Selection | |
| Region: | AfricaAsiaAustraliaCanadaChinaEuropeIndiaJapanKoreaMalaysiaMexicoMiddle East(Algeria/Syria/Yemen)Middle East(Turkey/Egypt/Tunisia/Kuwait)Middle East(Saudi Arabia)Middle East(United Arab Emirates)RussiaSingaporeSouth AmericaTaiwanNorth America |
| Advanced Wireless Settings (2.4GHz b/g/n) | |
| Enable SSID Broadcast | |
| Enable 20/40 MHz Coexistence | |
| Enable WMM (Wi-Fi multimedia) settings | |
| CTS/RTS Threshold (1-2347) | |
| Preamble Mode | Automatic Long Preamble Short Preamble |
| Transmit Power Control | 100% 75% 50% 25% |
| Advanced Wireless Settings (5GHz 802.11a/n/ac) | |
| Backhaul Topology |
| Enable Daisy-Chain Topology |
| Backhaul Password |
| Orbi can generate a new hidden password to improve security for its backhaul connection. |
| WARNING: Generating a new password might cause the Orbi satellite to lose connection from the Orbi router. To reconnect, use the Sync button. |
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices |
| Enable MU-MIMO |
| Enable Fast Roaming |
| Region | North America |
| 2.4G Channel | Auto ( 1 ) |
| 2.4G Mode | Up to 400 Mbps |
| 5G Channel | 36+40+44+48(P) |
| 5G Mode | Up to 866.7 Mbps |
