AwesomeQA
Jul 18, 2020Apprentice
RBR50 with 7 Sats High CPU utilization
Hello, I have 5 Sats currently connected to RBR50 ethernet backhaul and 2 sats connected as wireless backhaul with the latest firmware 2.5.1.32. I noticed that RBR50 CPU runs between 80% to 90% wit...
- Jul 26, 2020
Now RBR50 CPU runs from 6% to 30% with FW V2.3.5.30 with 7 Sats with no issues.
It appears to me that FW 2.5.x is too buggy and needs more work.
Jul 18, 2020Guru - Experienced User
Is this usage capture with everything online including wifi and wired devices or just the RBR and RBS alone? Something to try as well. disable ALL wired and wireless devices. Leaving the RBS online. Check CPU usage...
AwesomeQA wrote:Hello,
I noticed that RBR50 CPU runs between 80% to 90% with 25 connected device and armor enabled, devices are cell phones, and smart tvs.I have fiber speed 500 Mbps download, and 128 Mbps.
I have noticed that internal speed test stops running if the RBR50 runs for a week, and acts weird and slows down, so I have to reboot it weekly.
Do you have any suggestion?
