AwesomeQA
Jul 18, 2020Apprentice
RBR50 with 7 Sats High CPU utilization
Hello, I have 5 Sats currently connected to RBR50 ethernet backhaul and 2 sats connected as wireless backhaul with the latest firmware 2.5.1.32. I noticed that RBR50 CPU runs between 80% to 90% wit...
- Jul 26, 2020
Now RBR50 CPU runs from 6% to 30% with FW V2.3.5.30 with 7 Sats with no issues.
It appears to me that FW 2.5.x is too buggy and needs more work.
AwesomeQA
Jul 23, 2020Apprentice
I tried AP mode, disabeling Port Scanning and DoS protection ..etc.
It didn't decrease the CPU usage.
I found the issue is with all after Firmware Version 2.3.5.30.
I restored my router to 2.3.5.30 now, CPU runs smoothly and no issues.
so I think Netgear should the CPU hogging issue for firmware 2.5.x on RBR50.
Jul 23, 2020Guru - Experienced User
And did you factory reset the entire system after recent FW was loaded and check the CPU usage again? This should need to be checked.
I believe Orbi wasn't designed to have more than 3-4 supported RBS connected so even if v30 is working ok with 7, maybe more recent version of FW make this more apparent.
Heres mine with v16 loaded and just two RBS connected:
| Basic Infomation | ||
| CPU Load | 15.0718% | |
| Memory Usage(Used/Total) | 145MB/495MB | |
| Flash Usage(Used/Total) | 2945MB/4096MB | |
| Network Session(Active/Total) | 861/65536 | |
| System Uptime | 01:21:20:30 |
