ksagarzazu
Sep 21, 2020Aspirant
RBR50 with a fucsia dot on the network map
my router on the network map appears with a fucsia dot, whilst the satellite with a green one and on the main scree of my app next to the image of the router with the moving disc it says Internet: of...
Sep 21, 2020Guru - Experienced User
what modem/gateway are you connected to?
A combo device can cause a double nat and give you that.
https://kb.netgear.com/30186/What-is-Double-NAT
ksagarzazu
I will try to answer your questions I hope im getting the answers right
gateway 212.158.250.32
after i can read default gateway 192168.1.1
I cant find anything for modem
- plemansSep 21, 2020Guru - Experienced User
the orbi is plugged into something providing internet. Whether it be a modem, ont, gateway.
What device (and model) is it plugged into?
- ksagarzazuSep 21, 2020Aspirant
Wi-Fi Hub (Vox 3.0/THG3000G) vodafone is my provider
- FURRYe38Sep 23, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
ksagarzazu wrote:Wi-Fi Hub (Vox 3.0/THG3000G) vodafone is my provider
