Laineybirdy
Feb 19, 2020Aspirant
RBR50 with AT&T Arris BGW210-700 - setup
I would be forever grateful if someone would please give me explicit instructions for setting up my Orbi (RBR50) with my new AT&T fiber router (Arris BGW-210-700) I have been all over trying to find ...
CrimpOn
Feb 27, 2020Guru - Experienced User
Laineybirdy wrote:1. The AT&T service is also providing telephone service.
2. The Arris is connected to a fiber ONT
3. The only thing I have physically connected to the Arris is the Orbi modem but there are other devices that are connecting to the AT&T network and not the Orbi network. I'm not sure if your question was do I have anything physically connected. I have seen a screen showing devices that are connected and most are connecting to the Arris. I think this is what you explained with the double NAT - there are two networks.
Using the Arris for telephone means it has to stay.
No devices physically wired to the Arris (everything on WiFi) means that "Double-NAT" issues are less likely. (However, if in the future you decide to implement VPN into the Orbi or have problems with internet gaming, it will be time to revisit the issue.)
So, to start with, I would define the Orbi with the same WiFi credentials as the Arris and turn off WiFi on the Arris. Everything connects to the Orbi, which connects to the Arris. My Orbi worked this way for over a year, and I suspect thousands of other Orbi's around the world do today.
One "benefit" of this arrangement is that should you have a problem with the Orbi, you can simply remove it, turn the WiFi back on the Arris, and everything will connect to it.
As far as WiFi coverage, WiFi radio power is defined by the FCC. One single Orbi WiFi router will have about the same coverage as one Arris WiFi router. That's why Orbi has satellites: to extend the coverage.
Laineybirdy
Feb 28, 2020Aspirant
Thank you! Another question, You say to define the Orbi with the same WiFi credentials as the Arris. Do you mean to give it the same name (SSID) and password as the one I have for the Arris? I have reset my Orbi and gone back through the process of re-setting it up. I gave it the same name and password as the Arris but it is not connecting. I'm thinking maybe I didn't understand what you meant about "define the Orbi with the same WiFi credentials as the Arris."
- FURRYe38Feb 28, 2020Guru - Experienced User
Yes you can setup the Orbi for the same SSID name and PW. Just be sure you disable ALL wifi radios on the Arris modem.
- CrimpOnFeb 28, 2020Guru - Experienced User
Laineybirdy wrote:I gave it the same name and password as the Arris but it is not connecting. I'm thinking maybe I didn't understand what you meant about "define the Orbi with the same WiFi credentials as the Arris."
My point was that it is tedious to go around to every device in the house and change the WiFi connection. So, giving the Orbi the same WiFi means that when the Arris WiFi is turned off, every device will look around and find the Orbi with the same credentials. Less work for you.
- LaineybirdyFeb 28, 2020Aspirant
Ok - I think I finally have it configured as you suggested and it seems to be working.
* I had to wait to turn off the WiFi radios on the Arris until I went through the process with the Orbi to set it up. Once it went through the setup and told me it couldn't find the network, I then turned off the two WiFi radios on the Arris and it worked.
Thank you both for all of your help - I truly appreciate it. I am exhausted!! :)
Glad you got it working. I know it can be a hassle for some inexperieced users.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
