madhatter's avatar
madhatter
Apprentice
Mar 06, 2020
RBR50 with both RBS50 AND RBS40 Satellites
I have an RBS50 and 2 RBS40's connected wirelessly to my RBR50.  All works fine.  Now a new firmware upgrade has become available for the RBR50 and RBS50, but NOT for the RBS40's.  Do I upgrade the 50's or is it best to leave everything at the same firmware level?  The 40's and 50's are currently running v2.3.5.30 and there is now a new v2.5.1.8 for the 50's.
  • Retired_Member's avatar
    Retired_Member
    Mar 06, 2020
    No....if your system is working....leave it alone.
    Retired_Member
        Retired_Member
        madhatter wrote:
        thank you
        You're welcome....FYI....when your system NEEDS and update NG will push it auto-pilot.  You need to do nothing.
