ahmer1213
Dec 23, 2019Guide
RBR50 with Firmware 2.5.1.8
I just did a manual update to 2.5.1.8 from 2.5.0.38 as I also added a 4th satelitte. Everything is connected via ethernet backhaul. Everything is running fine (ALL wifi switches and echo dots ...
coretech51
Jan 08, 2020Tutor
Hi,
I came to the community to see if I can fixed the same problem with my devices not showing up properly in the Orbi app and webbase version. I'm still running firmware version 2.5.0.38. So, the problem you may be having is not due to the new update v2.5.1.8. Does it make since for me to update to v2.5.1.8 before the device problem is fixed?
Thanks,
Aaron
ahmer1213 wrote:I just did a manual update to 2.5.1.8 from 2.5.0.38 as I also added a 4th satelitte. Everything is connected via ethernet backhaul.
Everything is running fine (ALL wifi switches and echo dots work) except now ALL my devices connected to wifi both on orbilogin and the orbi app have disappeared from DEVICE MANAGER on the orbi app as well as the orbilogin.net page. Only the HARDWIRED ethernet devices are showing up. I had to do a manual update on the router and the orbi satellite as the AUTO-updater was not updating my newest satellite from formware ver 2.3.1... while the router and my 3 satellites were sitting with ver 2.5.0.38.
Can anyone guiode me on what to do? I also can't find the 2.5.0.38 and am afraid I may have to do a hard reset.
Thoughts?
tomschmidt
Jan 08, 2020Virtuoso
The v2.5.1.8 firmware release for the RBR50 and RBS50 does fix the device naming issues caused by v2.5.0.x firmware. NG has removed v2.5.0.x from their downloads due to the bugs in it. You have to manually update to v2.5.1.8, as the auto-update feature is disabled, NG broke too many users by autoupdating their routers with defective firmware.
- FURRYe38Jan 08, 2020Guru - Experienced User
Also if after updating to v2.5.1.8 exhibits problems, a factory reset and setup from scratch should be performed. I updated to v2.5.1.8 and didn't factory reset. Have had zero issues and device naming is working well on a RBK50.
Working for others as well:
- peteryungJan 08, 2020Tutor
Thanks for the Hard Reset tips. Might try if I have time.
Ya, sometimes there needed as a last resort. Others are reporting good operations with v2.5.1.8. When you do get it reset and setup again, be sure to save a backup configuration to file for safe keeping.
If your system is out of warranty, you can also give Voxels FW for Orbi a try as well.
peteryung wrote:Thanks for the Hard Reset tips. Might try if I have time.
