ahmer1213
Dec 23, 2019Guide
RBR50 with Firmware 2.5.1.8
I just did a manual update to 2.5.1.8 from 2.5.0.38 as I also added a 4th satelitte. Everything is connected via ethernet backhaul. Everything is running fine (ALL wifi switches and echo dots ...
Sevwren
Feb 12, 2020Tutor
So glad I came across this post. I was just about to decide to pull the trigger and go ahead with a manual update from version V2.3.5.30 to the latest 2.5.1.8 as neither in the web interface nor the orbi app has the feature 'Online Update' returned any updated firmware version info.
Recently logging into the gui for my EX3700 WiFi Range Extender showed the "New update is available". Now of course that thing seems to be behind by 9 versions of firmware releases however.
Def will wait for awhile to go ahead with the V2.3.5.30 update.
- FURRYe38Feb 13, 2020Guru - Experienced User
Been no issues with v2.5.1.8. Solid and stable.
v2.5.1.8 is a minor update and thus may not appear in a auto FW check or Orbi app. Others have seen it appear in the Orbi app.
I manually downloaded it and manually installed it. RBS first, then RBR lastly. Zero issues. Solved a device naming problem in v38 and v40.
Good luck.
Sevwren wrote:So glad I came across this post. I was just about to decide to pull the trigger and go ahead with a manual update from version V2.3.5.30 to the latest 2.5.1.8 as neither in the web interface nor the orbi app has the feature 'Online Update' returned any updated firmware version info.
- coretech51Feb 13, 2020TutorI performed the manual update to Firmware v2.5.1.8 and everything except Circle is working fine. I had issues with NETGEAR Circle losing its connection before updating to v2.5.1.8.
- FURRYe38Feb 14, 2020Guru - Experienced User
Seen others with Circle issues. I recommend if your needing circle to work, please post about Circle over in the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck.
coretech51 wrote:
I performed the manual update to Firmware v2.5.1.8 and everything except Circle is working fine. I had issues with NETGEAR Circle losing its connection before updating to v2.5.1.8.- radamoFeb 14, 2020Apprentice
Just did a manual update to Satellite and then Router for version 2.5.1.8. All went smooth. Things seem to be operating well. Hopefully it will stay that way!
