ahmer1213
Dec 23, 2019Guide
RBR50 with Firmware 2.5.1.8
I just did a manual update to 2.5.1.8 from 2.5.0.38 as I also added a 4th satelitte. Everything is connected via ethernet backhaul. Everything is running fine (ALL wifi switches and echo dots ...
Sevwren
Feb 12, 2020Tutor
So glad I came across this post. I was just about to decide to pull the trigger and go ahead with a manual update from version V2.3.5.30 to the latest 2.5.1.8 as neither in the web interface nor the orbi app has the feature 'Online Update' returned any updated firmware version info.
Recently logging into the gui for my EX3700 WiFi Range Extender showed the "New update is available". Now of course that thing seems to be behind by 9 versions of firmware releases however.
Def will wait for awhile to go ahead with the V2.3.5.30 update.
Feb 13, 2020Guru - Experienced User
Been no issues with v2.5.1.8. Solid and stable.
v2.5.1.8 is a minor update and thus may not appear in a auto FW check or Orbi app. Others have seen it appear in the Orbi app.
I manually downloaded it and manually installed it. RBS first, then RBR lastly. Zero issues. Solved a device naming problem in v38 and v40.
Good luck.
Sevwren wrote:So glad I came across this post. I was just about to decide to pull the trigger and go ahead with a manual update from version V2.3.5.30 to the latest 2.5.1.8 as neither in the web interface nor the orbi app has the feature 'Online Update' returned any updated firmware version info.
