ahmer1213
Dec 23, 2019Guide
RBR50 with Firmware 2.5.1.8
I just did a manual update to 2.5.1.8 from 2.5.0.38 as I also added a 4th satelitte. Everything is connected via ethernet backhaul. Everything is running fine (ALL wifi switches and echo dots ...
Feb 14, 2020Guru - Experienced User
Seen others with Circle issues. I recommend if your needing circle to work, please post about Circle over in the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck.
coretech51 wrote:
I performed the manual update to Firmware v2.5.1.8 and everything except Circle is working fine. I had issues with NETGEAR Circle losing its connection before updating to v2.5.1.8.
radamo
Feb 14, 2020Apprentice
Just did a manual update to Satellite and then Router for version 2.5.1.8. All went smooth. Things seem to be operating well. Hopefully it will stay that way!
- FURRYe38Feb 14, 2020Guru - Experienced User
Good. Be sure to make a backup configuration to file for safe keeping.
Enjoy. :smileywink:
radamo wrote:Just did a manual update to Satellite and then Router for version 2.5.1.8. All went smooth. Things seem to be operating well. Hopefully it will stay that way!
- EchostormFuryMar 07, 2020Apprentice
I can confirm too, I did the automatic update to 2.5.1.8 and all my devices went missing. Further the satellite backhauls were viewed as disconnected even though they worked. But my devices kept conflicting IP's and caused numerous disconnects. Had to revert and downgrade.
- radamoMar 07, 2020Apprentice
So odd how everyone gets different results. Since upgrading I have not had one issue. System has been rock solid.
- theoakMar 07, 2020Luminary
EchostormFury wrote:I can confirm too, I did the automatic update to 2.5.1.8 and all my devices went missing. Further the satellite backhauls were viewed as disconnected even though they worked. But my devices kept conflicting IP's and caused numerous disconnects. Had to revert and downgrade.
I experience the same with 2.5.1.8. My Orbi system is in Access Point mode. I discovered that if I have Daisy Chain ON, the connected device list and Satellite connection status works fine. If I turn it OFF, then I lose everything and the satellites show as disconnected. It does show both satellites as connected to the router even with Daisy Chain ON. Give that a shot?
That setting is found in Advanced - Advanced Setup - Wireless Settings - Backaul Topology.
- FURRYe38Mar 07, 2020Guru - Experienced User
Next time try a factory reset on the RBR and RBS after updating FW. I'm on v2.5.1.8 and all devices appear. Mine was factory reset and setup from scratch
One thing about Daisy Chain, if it's not needed Turn it OFF on the RBR first before connecting or using any RBS.
