ahmer1213
Dec 23, 2019Guide
RBR50 with Firmware 2.5.1.8
I just did a manual update to 2.5.1.8 from 2.5.0.38 as I also added a 4th satelitte. Everything is connected via ethernet backhaul. Everything is running fine (ALL wifi switches and echo dots ...
keithsplaceORBI
Mar 07, 2020Tutor
When is Netgear going to fix this devices not showing up after Firmware update?
Seems like they are not going to work much for previous gear. Seemed that they where straight on it when it was new,
Now that it's a couple years old they just gonna patch a few security holes at best.? Starting to loose my fath in NG.
Mar 07, 2020Guru - Experienced User
Next time try a factory reset on the RBR and RBS after updating FW. I'm on v2.5.1.8 and all devices appear. Mine was factory reset and setup from scratch
One thing about Daisy Chain, if it's not needed Turn it OFF on the RBR first before connecting or using any RBS.
keithsplaceORBI wrote:When is Netgear going to fix this devices not showing up after Firmware update?
