CReinhard
Aug 06, 2019Aspirant
RBR50 WIth FW 2.3.5.30 Dropping Conection all the time
I have the RBR50 and RBS40 and RBS30 Satlites , My Wan is a Point to point Airfiber contection this has been flawless for months , Now with this new Firmware I have to constantly reboot the Router ...
Aug 06, 2019Guru - Experienced User
Try a factory reset and setup from scratch before downgrading FW.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
CReinhard
Nice caned responce
System has been flawless untill 2.3.5.30 .. Thats the issue here not my setup , I have reset it and I have the same issues , I am a Large Netgear Reseller I would never recomed this system to anyone because of the constant pain when you people break your firmware
- FURRYe38Aug 06, 2019Guru - Experienced User
Then downgrade FW.
Questions are for us so we can get a better idea of the situation. Not everyone has the same configurations. If you don't give feedback then it's hard or anyone to help you.
V30 has been working for others as well. Mines currently loaded since v30 appeared. Zero issues.
If your a NG reseller then maybe you should find more official NG support lines.
Good Luck.
