GatorMitch
Jun 14, 2024Aspirant
RBR50 with Quantum fiber
So I just got Quantum fiber installed after having spectrum cable internet for years. I know the RBR50/RBS50 are legacy mesh systems by now. The Quantum installer brought 3 of their mesh pods for me ...
CrimpOn
Jun 14, 2024Guru - Experienced User
GatorMitch wrote:
SThe Quantum installer brought 3 of their mesh pods for me to use. When he saw the Orbi he said he can just connect nid output directly to the Orbi and my network would stay the same.
As you are aware, the original Orbi system is WiFi5, which was the prevelant WiFi standard in 2016 when the Orbi system was released. In the past eight years, new WiFi standards have become common, including WiFi6, WiFi6E, and now WiFi7. These are all "backward compatible" with WiFi5 in the sense that older devices continue to connect and function. As long as the customer has few devices capable of WiFi6, 6E, or 7, then deploying a newer system has little value.
From the post, it appears that those three units are sitting in a box unused. Are you being charged a monthly fee for them?
The installer was correct that all existing WiFi devices will connect as long as the WiFi system has exactly the same WiFi credentials as the existing Orbi. (SSID/password) Thus, you are free to experiment with using one system or the other just by moving the cable from one router to the other (and back). You could configure the ISP units to match the Orbi credentials. Power off the Orbi. Move the cable. Power up the ISP system. (I would do this when people are not actively using the system.)
It might be worth taking a few minutes to:
- Inventory your WiFi capable devices. Do you have smartphones, tablets, Chromebooks, laptops, televisions, or Desktops that support WiFi6 (or newer)? (I now have three -wow!, and am not motivated to consider purchasing a replacement for four Orbi units.)
- Understand what the fiber company delivered. i.e. look up the specs on the internet. (If you provide the specific brand and model number, perhaps someone on the forum can comment from experience.) Would three WiFi access points provide additional coverage that would be worthwhile?
- Confirm what you are paying for. If you are not going to use them, will you save money by returning them?
- GatorMitchJun 14, 2024AspirantThanks for your comprehensive reply. I probably have some wifi6 capable devices (iPhones, Apple TV, laptop). Not worth upgrading my old Orbi, but might be worth trying the pods quantum gave me. The pods are included with my service so no added monthly charges. The pods are model Q9500WK. How would I go about signing the pods the same Wi-Fi credentials to the pods so all my network devices would see the pods just as they see the Orbi? From what I understand the pods are Wi-Fi 6. Not sure if I would notice anything different with them as all my devices are working fine with the higher speeds that I’m getting from the Quantum fiber.
- CrimpOnJun 14, 2024Guru - Experienced User
Does this product appear to match?
Notice the link on this page:
https://www.quantumfiber.com/support/equipment/user-guides/wifi-pods.html
How do I Connect and Control my Pods?
("using the 360 WiFi app")
My guess is that any WiFi6 capable devices will report a higher internet Speed Test when connected to one of these pods than when connected to the Orbi system. Of course, a video will stream only as fast as it streams. Music will play. web pages will open 1/2 second faster.
