Suzq716
Feb 20, 2020Aspirant
RBR50 with RBS50 & RBS40 WiFi has slowed down from 117 to under 10
I have the router with the 2 satellites. Trying to figure out why WiFi has slowed down so much. Nothing has changed with where the units are set up and nothing has changed in the house. I have 80 WiF...
tomschmidt
Feb 20, 2020Virtuoso
Suzq716, if you are running v2.5.0.x firmware, and it was retracted by Netgear after many bugs and stability issues were found. NG disabled autoupdate in recent releases due to the issues that it has caused. I suggest manually upgrading your RBR50 and satellites to v2.5.1.8 if you are running v2.5.0.x firmware. It is available from https://www.netgear.com/support/product/RBK50.aspx#download
Upgrade the satellites first, then the router.
Suzq716
FW is 2.5.1.8
