Sherich
Jan 27, 2022Tutor
RBR50 with StarLink
Greetings! I'm new to the forum so thanks in advance for pearls of wisdom from the collective . . . I am in the process of installing and setting up the new version 2 (rectangular dish) StarLink...
Jan 27, 2022Guru - Experienced User
Why not do it the simple way?
Leave the Starlink router in router mode and put the netgears IP address into it's (starlink router) DMZ?
that'd let you still be able to use the starlink app/features and all traffic gets forwarded to the netgear router.
I don't have a starlink devices to play with (maybe someday) but that'd be the router I'd follow.
Sherich
Jan 27, 2022Tutor
Thanks for the quick response, much appreciated!
As I understand it, the StarLink router has little-to-no accommodations for making modifications. In time, I'm sure this will change. I don't deal with all these configurations often so forgive if I'm not stating this correctly - - - currently the StatrLink router does not have a Bridge Mode nor any Port Forwarding.
Regards . . .
